Jump to content
Colour Classic dark and cold, salvage attempt, MB recap and boostrapping
Recommended Posts
  • 68kMLA Supporter
from https://68kmla.org/forums/topic/62716-colour-classic-1993/
Hi all,
ok, I recapped the MB (I removed the ROMs for the cleaning process)
I was wondering how to bench test the MB
Why don't I just snap it in? Because I've not yet finished recapping the PSU/AB.
I was not able to find the pin out of the left connectors: from top-down: the first 5 pins are +5,+5,GND,GND, +12 (it should power up the MB), the second (hair comb style) is the HD , the second the FDD. Still I miss the video signals and speaker.
I feel clumsy with this machine, I feel more comfortable with LCs, Plus, SEs.
Can someone please redirect me where to find documentation?
Also, I read this Mac has an hybrid soft-power on, PSU switch + keyboard button. Can it be bootstrapped like the Mac II?
Link to post
Share on other sites
  • 68kMLA Supporter
@bibilit ah! Thanks pal. this is interesting!! Now I need to know how to feed the MB with voltage: are the 5 pins on the top most connector (relative to my photo)?
more about the AB+PS:
I replaced all the capacitors recommended by Bruce.
During bench testing the voltage are unstable, shifting from +3.5 to +5, and from +8.5 to +12 on the HD pins, apparently the +5V and +12V are available without soft power.
The voltage are shifting also at the beginning of the low voltage section, just after the flyback transformer.
I tested the optocoupler (I identified a diode in on side and a transistor on the other, I can not do more then this), I replaced the regulator. no improvements.
I checked all the solder joints, they look just fine.
I'd go for replacing the MOSFET now but I'm going blind, I can not make better diagnose.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
