sircabulon Posted July 28, 2008 Report Share Posted July 28, 2008 I loved my Newton Message Pad 130 and used it everyday, but one day the batteries died. I didn't get around to replacing them for a couple of weeks, but when I did get around to replacing them, the stupid thing wouldn't turn on! !]'> I tried more than one set of batteries with no luck. Got any ideas? Quote Link to post Share on other sites
madmax_2069 Posted July 28, 2008 Report Share Posted July 28, 2008 maybe somehow the battery contacts are corroded and need cleaning, or connections got bent somehow. i would check them to see there condition. if that don't work then something internal happened to it Quote Link to post Share on other sites
macgreg Posted July 29, 2008 Report Share Posted July 29, 2008 Also try testing the internal backup battery (silver disk). If you had dead AA batteries and were running on backup for a while you may have drained that as well. Quote Link to post Share on other sites
madmax_2069 Posted July 29, 2008 Report Share Posted July 29, 2008 ahh yea the pill battery. i totally forgot the models under the MP 2000 had them. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
