Installed new pram battery as I say on another thread, and these replacement cells seem to work fine, though to be honest, not having a multimeter, I haven't tested the charge properly.
While I had it apart, I also installed a 30GB Fujitsu drive. Now the drive is large and wonderfully silent, makes the thing fast, and so forth: I like it. However, the machine now will not awaken from sleep: I just get a blank screen, forcing a reboot. No GLOD, thankfully, but this is no use either. Same story on battery power or mains.
I noticed this information while a-Googling on the subject:
"A sleep problem can emerge if you install a 20GB (maybe larger) IBM HD into a Wallstreet. The problem is that the high level of magnetic force exhibited by the drive can affect the sleep mechanism on the Wallstreet, to the extent that the system won't sleep when shutting the lid (the mechanism is magnetic)."
Has anyone had analogous troubles on installation of a large drive in a 2400c? I don't WANT to take the thing apart again (10 times already?), but it seems I have to. But what to do when those 25-odd screws come out, that is the question!
