I started this quite some time ago, then ran into problems and let it rot for some months, but I now have a usable version.
FuseHFS is a MacFUSE filesystem that provides write support for HFS disks.
I haven't tried it with real media, but you can create HFS disk images, mount them, and copy things to/from them.
For Mini vMac/Basilisk/SheepShaver, you should make sure the disk image has no partition map, or else it won't be recognised.
Features:
Requirements:
Known bugs:
It's quite an early beta, but I'd like people to try it so we can find more bugs, and maybe even fix them some day.
Download: http://namedfork.net/fusehfs (139 KB)
Source code: http://vc.namedfork.net/nf/fusehfs/
Screenshot of Disk Utility
: http://yfrog.com/5nhfsimgp
It's based on hfsutils, and licensed under the GPLv2
Try it out and tell me what you think.
Features:
- Format and read/write HFS partitions
- Supports HFS file attributes and resource forks, of course
- Automatically blesses a folder when you copy a valid System file into it
Requirements:
Known bugs:
- I don't recommend editing resource forks directly on the disk image, the documentation on setxattr isn't that clear about when/if an attribute should be truncated, and my testing on the subject was inconclusive, instead just use it to copy files to/from the HFS disks.
- It can't change volume names, since that only works with apple-provided file system modules, MacFUSE can't do it.
- The code is there to support creation/backup dates on items, but for some reason it never gets called, so they don't appear anywhere
