True, though I personally haven't seen any problems in normal use. Seems as strong as it was before. I also have never soaked anything, just a spraying over the outside.This is a very aggressive recipe that will whiten the case (definitely) but which will reduce the strength of the plastics. We are looking for a recipe that will whiten the outside of the Mac without attacking the structure of the case.For lightening Macs I just use an even 50/50 mix of Clorox Outdoor and water, give it some good sun exposure and spray it over 3-4 times. Even very badly yellowed Macs I can at least get down to a much more pleasing beige color. Milder yellowing can turn out virtually indistiguishable from the original platinum. The process preserves the texture but does kill some of the sheen. Still experimenting with the best ways to restore that.
Sadly everything I've ever come across or thought up myself for a gentler process still involved abrasives that remove plastic, once you get down to the core of how it works.
