I think almost all PBs take 24V, but I could be dead wrong. Sure isn't a yo-yo, and you wouldn't easily find one for free. /hj
Never thought of recapping a wall wart before. Makes sense.If you want to use it, keep in mind that you should really recap it. I think almost all of them are starting to fail by now.
Yes, using a vice and two rods (screwdrivers for instance) does the trick pretty well.Crack the seal and hope it goes back together?
How do you open it? Crack the seal and hope it goes back together?
I don’t understand that, because the amperage of a power adapter is its maximum output, and the device that it’s plugged into draws what’s needed.It officially shipped with the 150. The only one of those supplies that can supposedly damage the 100 and maybe the 150 are the 3-amp adapters that shipped with the 165c and 180c.
