What is the Maximum OS for an Imac G4 800 mhz
I use 10.4.11 on mine... but, I have never tried to go "up" from there..
I have the capability to try to go to 10.5, Just don't see a good reason to do so.
Try it if you have it, If not LMK and I believe that I could try for you!
RP
The official minimum install for 10.5 is 867 MHz; so your model *JUST* missed it. Although 10.5 generally can be made to install without issue on systems that are just under that spec. I have a G4 Digital Audio, one generation older than the minimum-supported for 10.5, and it installed just fine even with a 450 MHz CPU, using an OpenFirmware trick. It ran just fine when I upgraded to a dual 1.0 GHz, and then to a single 1.5 GHz. It also runs fine on my minimum-spec PowerBook G4 867 MHz.
You can run 10.5 if you want. 10.5 generally takes more memory, but is generally faster. Much new software requires 10.5 as a minimum, plus you get Time Machine.
I did the:
dev /cpus/PowerPC,G4@0
d# 867000000 encode-int " clock-frequency" property
and after that was done I typed mac-boot hit enter and hit the C key as soon as possible.
Glad to see my OF hack passed around still :D
imac600 also made a great little utility called LeopardAssist that you can use if there is already an OS X version running on the Mac.
In my experience, 10.5 is slower. (At least on 1GB of RAM or less, which for a lot of G4s is the absolute- or practical max.)
Also note that you lose Classic.
