Wacom serial cable pinout?
Hi folks,
Does anyone have a Wacom tablet that uses a serial cable who can share the pinouts from plug to plug as I'm trying to make one up.
It's the cable with the DC power input on the mac serial plug and a 9pin connector on the other end.
Cheers all.
Sophie,
In case no one finds one, if you have a multimeter, see which pin connects to which via continuity testing. That should be easy enough.
