Virtual PC 7 not recognizing XP CD?
BGoins12
So this is driving me nuts. I bought a new in box copy of Virtual PC 7 at the flea market for $10! Problem is, I can't get the dang eMac to pick up the XP Professional CD. I followed the instructions it gave me, and it says "OS not found. "Install an OS on this hard drive" and Reboot and select proper boot device, which I am. Anyone know why it's doing this? I know there's nothing wrong with the drive or the CD. Any ideas on this?
Computer is a 1.42GHz eMac with 2 gigs of RAM running Leopard.
Ok, it doesn't recognize W98, 2000, XP Pro or Ubuntu/Kubuntu. But it recognizes Vista. It will get to press any key to boot, and then it says it cannot be installed on this PC. I know that since it's not programmed to accept Vista.
I run VPC on my imac G5 1.9ghz, and actually its surprisingly quick in windows 2000. XP is a bear, so i dont bother as runs about as slow as a spyware riddled environment on an atom PC.
