I have found a cheap SE/30, cleaned the board, new caps around.
The board got a chime but I have no vertical sync. I have just a bright line in the middle of the screen.
The analog board is not the issue, tested ok. Logic board is the problem.
So far, I have tested the continuity from the connector to both Pals and I have replaced LS166 (was bad anyway) but no improvement.
Any ideas ?
Any ideas ?
