Using Compact Virtual Memory 3.0.2 on a Mac SE (7.1) with a MacEffects Performer.
Has anybody tried this and got it working OK? Lots of different threads suggest it works fine with many different accelerator cards. Plus I saw MicroMac's own pages suggest you try it.
However, when I've tried it everything seems to work fine and Finder shows the virtual "ram". However, there are two issues. AppleTalk is broken and whereas you can shutdown the SE, if you try to restart you get a few display glitches and then it hangs and you have to power cycle it.
I tried with the MM Performer 2.1 extension (in the Extensions folder with an alias in the Control Panel folder. This also comes with an AppleTalk patch extension, which does not really seem to do anything for me as AppleTalk works fine without it (without Compact Virtual of course!).
Thanks!
I know it has to load before on *some* accelerators though I must emphasise that in this case it is a wild guess rather than being based on deep knowledge...
My apologies. It's loading first! Not sure why as there's nothing special about the naming. As far as I understand extension are loaded in alphabetical order?
So on the tried and tested method of "if it does not work one way, try the other" I moved the Virtual extension to load after the MMPerformer extension. The first time it restarted after loading the MM Performer extension. But on the second boot is loaded up fine. Unfortunately it did not make a difference! Virtual memory is still working, but Appletalk and restarting are still broken.
For virtual did you run the installer or just drop the extension in to the system folder? If I remember correctly virtual must be installed so it can detect what accelerator is in your system as part of the installation process. I remember having an issue with one of my accelerators that went away after I did an install vs. a copy.
Thanks. I ran the installer. It asked me what card was in there. The closest one was a Micromac one but I cannot actually remember which one! I will rerun the installer.
Approximately. Here's more detail than you needed or wanted :-) [and from memory, too, so may be slightiy inaccurate].
Extensions/INIT resources are loaded by file type, and within each file type they're loaded alphabetically.
First are loaded script extensions, which have a file type of 'scri'. These are intended to add support for other writing systems, and they are loaded before the System attempts to display any text.
After that, 'adev's are loaded, which are AppleTalk drivers. After that, AppleTalk itself is loaded.
After that, INITs (normal Extensions) are loaded, and then INIT resources in cdev files. The immediate practical upshot of this is that control panels always INIT after INITs, and some drivers that really want to load early masquerade either as 'scri's or, more riskily, 'adevs'.
Approximately. Here's more detail than you needed or wanted :) [and from memory, too, so may be slightiy inaccurate].
Thanks for that! Interesting.
I just had another play with Compact Virtual. I tried MacTCP with the DaynaPort drivers since the SE has a BlueSCSI. With the Compact Virtual EXTEND MEMORY option toggled on this also fails to work (for me!). But if I toggle it OFF Appletalk and TCPIP work fine. Also the Gemstart 3.0 extension allows me to restart fine. With the MM Performer 2.2.1 extension restarting the SE hangs with EXTEND MEMORY enabled.
Both extensions give similar performance as tested with Speedometer 3.23.
