Hi everyone,
I recently got a few compact macs from a craigslist seller - 2 128's, an SE and a Plus.
Tried them all out - SE is fine, Plus is not working (though I'll address that one later), and one of the 128s seems to be in working order, asking for a boot disk.
The other 128, unfortunately, is not so happy.
Turn it on, no startup bong sound, and the screen shows thick vertical lines. There are also some sprinkled pixels on the right side of the screen, and a few flashing pixels scattered through the rest of the display. No sad mac code visible.
This is an older 128, with just "Macintosh" on the back badge instead of "Macintosh 128k"
I have a copy of Pina's "Macintosh Repair&Upgrade Secrets" but couldn't find anything that seemed to apply to this problem. I've heard that "Dead Mac Scrolls" may have some useful information, perhaps I should look for a copy.
Any ideas/advice? I could set the innards aside and try my hand at a non-destructive casemod of some sort, but I'd like to try resurrecting the 128 first if it's possible. Thanks!
Here are some images of the sad 128:
With flash:
w/o flash:
or check out the photoset here:
With flash:
w/o flash:
