Don't blame me, this one's Elfen's fault! [
He made a very interesting suggestion for a board cleaning setup. Its elegant simplicity set me to wondering about the frequencies of things like vibrating cutting tools and my hair clippers . . . which of course forced me to make the Duck Go (Google is now the enemy) to find some suggestions for low budget, wide area format cleaners for motherboards and the like.
I've already got a pair of sanders. Now I'm wondering how to get the AC motors to run out of phase to double down on the frequency? Splitting out the lines for running them on both phases available in my apartment's 220V clothes dryer outlet comes immediately to mind. [}
A standard dryer cord wired into a gang box switch/setup should be easily done with off the shelf parts from your local Big Box/real hardware/tool store ethnic cleansing unit.
***************** thought I'd add that the on-off switch would need to be double pole-single throw for emergency shutdown. A 220V double breaker might work.
Edit: second pass at the notion:
Determining which pair of 110V outlets in a home are wired to opposite legs of the breaker box and are close enough together near the cleaner kluge to run extension cords that are already on hand to power the sanders is likely the KISS compliant, zero cost solution here . . .
. . . but where's the fun in that? :-/
