Uh Oh: Stupid Compact Mac Networking Question Alert
I think that’s the correct serial cable for connecting a 512k’s DE-9 to a Plus’s miniDIN-8 over AppleTalk. But, as noted on the blog, the wiring of the cable matters, not just the shape of the plug.
LocalTalk or PhoneNET adapters would be another way to do it, as long as you can find ones that fit.
That looks like good information too. It matches the “elderly MacOS computer” cable from https://whitefiles.org/tec/pgs/h10b.htm as well.
Although now I’m confused by that ImageWriter II cable. I still think it was designed for this use case, but it seems weird (for any use case) that it omits DE-9 pin 3 (signal ground)…
