tunnel vision powerbook duo
Welcome,
... what model PB Duo? There are no substitute LCDs apart from the same model it comes with, from either a donor Duo or new old stock see Aliexpress sometimes for a match, but make sure they offer a full refund if dead on arrival ...
JB
Has to be a 250 or a 280. Good luck finding one without the problem, better bet is to fix your current one. Bake in the oven for 5-8 hours at exactly 100 degrees centigrade and it should clear up. Make sure to take the panel apart as much as possible first.
