Trying to fire up my Apple II Plus
CompuNurd
68000
I have had an Apple II Plus for a while, but never got around to messing with it. When you turn it on, it beeps once and the floppy drive spins and doesn't stop until you press the reset button. It doesn't load any disks, and it doesn't sound like it is trying to read the disks. I have pressed on all of the socketed chips to make sure they are fully seated and the issue still persists.
When you press ctrl-reset, the drive stops spinning and I get a cursor, but nothing happens when I type.
Any ideas?
Have you tried booting with the floppy drive (and Disk ][ interface card) disconnected?
Also, does the floppy drive zero when you boot it (sounds like 5 or so clicks), or just spin?
Have you popped the chips all the way out of the sockets (carefully, so as to not bend the pins) and then put them back in?  Often, they need more than a push.
It could also be a bad floppy drive, usually a dead chip in the drive itself doesn't prevent it from showing some sort of correct behavior; for instance, if one of the socketed chips inside the drive itself is bad, you may end up with a drive that is normally able to read but not to write any content. You might want to check them as well! Do you have any way to test the drive separately (i.e. another machine)?
EDIT: I actually read now that after using ctrl-reset, the typed characters don't show up on the display, this seems to point to some issue with the Apple II itself indeed. You might still check that floppy drive though, if it has some failed component it may be messing up with the main system in strange ways...
I have not done Apple II/II+ repairs in years but try the following Diags:
1) Like Jack stated, remove the Disk II card out the Apple and turn it on. It should Boot to BASIC with ']' and a flashing cursor.
2) Type. does the keyboard work? With the cover open feel the bottom rear of the keyboard, some of them have a switch on them, I believe this is for a Uppercase/lower case option, but not all Apples have them, just some. if the switch is there, slide it and try it.
2a) Check the keyboard ribbon cable. It should be a 16 flat wire cable with an IC Header on both sides. Make sure it is firmly seated in the sockets; one sock will be at the keyboard and hard to get too without unscrewing the case off the bottom panel... Check if the headers have all their pins. A loose or broken pin can create problems.
3) Assuming that the keyboard is fine or fixed, Look at the cable on the drive header on the drive card. Make sure all the pins are in the cable's socket. Off by a pin left or right or off by a row will cause problems and can even kill a drive! Look at the chips on the cards, are they OK looking (no cracks or bulges).
4) Assuming that the card is OK, open the drive. Take the cover off, and flip it over. See the motor spindle, drive belt and Disk Spindle (Large wheel with B/W pattern)? Does the motor spin with the Apple is turned on? Does the belt has some flex to it? Does the Spindle spin? There's a whole lot of other things to look at, and even adjust the speed of the hard drive from here but lets assume all this is fine and working...
5) Move the head to the spindle. and turn on the Apple. Does it move back? Inspect the arm above the head, does it have a cotton pad on it? Does it sit firmly on the head?
6) Check the chips on the controller board. They look OK? With the exception of 2, they are all 74LS series chips and easy to replace.
This is a simple diagnostics, everything else from here is just too detailed to list here. I could add more later.
At best, you may have to remove the boards and wiggle the chips on the sockets to clear the corrosion that has built up on them. At worst, you may need a new Disk ][ Card and Disk Drive. I forget which chip on the Disk ][ card that short out that kills disk drives, but that is fixable with replacing that chip on the Disk ][ card and all the 74LS chips on the Drive.
