Hi, I have a Powerbook 190cs and a Powerbook 165 that are having weird backlight issues. On both laptops, upon power on, the backlight will lit up for a while (5-10 seconds), then turns off. With this, I can still use the 165 since the screen is B&W, whereas the 190cs with color screen is totally unusable without the backlight. However, strangely on the 190cs, if I do not power it on for around 2-3 days, the LCD backlight will work fine for around 2-3 hours once it is turned on before the problem will happen again. Once the problem happens on the 190cs, I have to let it rest for a while before retrying. On the 165, the backlight symptoms are persistent and will not change regardless of how long I let it 'rest' before powering on.
On the 165, the issue happens regardless of whereas the machine boots from floppy or HDD. On the 190cs, the issue does not happen with floppy boot but only when booting from the hard disk drive. The 190cs has the PRAM battery removed, if that matters. (I have another 5300cs which also has the PRAM battery removed, but does not exhibit such symptoms)
The 190cs is on System 7.6.1 and the 165 is on System 7.5.5.
I guess the backlight hardware is most likely ok, since it works fine for a while when power is applied. It is also not a loose cable issue since I did not touch the cables when the problems happen. Any thoughts?
