I came across the manual for the Mac Plus in my closet today and flipped through it just for kicks.
On page 149, the following text gave me a good chuckle...I quote exactly from the manual here...
"It's fine to keep your Macintosh Plus switched on even when you're not using it. It uses very little electricity (about the same as a 60-watt light bulb), and it makes a fine night light."
The paragraph then goes on to caution about turning down the brightness to prevent burn-in. Immediately after that, in red text, is a warning against removing the cover from the main unit.
We all know the Plus has a fragile power supply due to its lack of a fan. I wonder if Apple wrote this advice to keep their repair techs in business? Power supply/analog board issues aside, Pluses are usually pretty sturdy. Seriously, using a CRT monitor as a night light?
There are some other funny bits in the manual, too, including a suggestion to store the computer in a bookcase as long as it's not there when it's on, how it "probably won't survive a cup of coffee spilled into it", and that you can "never hurt your Macintosh Plus by clicking in the wrong place". These are all just on page 149 alone!!
Citation: Macintosh Plus. Apple Computer, Inc, 1986.
