The Jaz self-terminates; I've been using one for years without anadditional terminator and have had no problems. If you still want toterminate it all you need to do is buy a standard 50-pin terminator and connect it to the open connection. Either connection should work, top or bottom, the drive doesn't seemto care where the scsi in is.
Thanks Janez, both for the drives and information.
Well i found this information, but apparently this is for the external drive only (a switch is provided to enable or not termination) more or less the way the Zip works.
