I have a classic with 4MB ram and 7.0.1. Does anyone know a decent gif/jpeg viewer or slideshow program that will work on this thing? Jpegview requires a 68020 and quicktime. Thanks!
I think "GIFConverter 2.3.7" will do the job; there's also GIFWatcher, but it only supports GIFs, not JPEGS. You can get both of those apps from here. You might want to either jump down to System 7.0 or System 6.0.x to minimize the RAM footprint. Also, I'm assuming you've got a hard drive installed, so I just wanted to make sure you did, since those two apps will need a hard drive to work. In a pinch, CMD + Option + X + O <--letter "O", if you don't want to install System 6.
