Macro Maker, I believe... I remember the icon was the typical "Mac" icon that the System and Finder had, but with a cassette sticking out of the monitor. The UI looked like a tape recorder.
The Apple software was MacroMaker. Set it up so the "F8" key on my original IIsi's AEK II would turn the volume up to max, then back to the normal volume level. Speaker was notorious for cutting in and out. Every subsequent IIsi I've owned, however, has not had that problem.
Prior to System 7, the OS has little interapplication communication and there is no true scripting. Userland Frontier relies on the same technology as AppleScript so it is System 7 only. There are a number of macro alternatives which drive the Mac interface.
AutoMac (Genesis Micro Software) -- also bundled with an early version of Word.
Tempo (Affinity Microsystems) -- later versions are System 7 only.
KeyQuencer -- shareware, later versions are System 7 only.
QuicKeys (CE Software) -- try version 2.0 or 3.0. QuicKeys plus DiskTop can transform System 6.
