System 1.0 book disk, how to
I finally have an M0001 original mac :beige: (no 128K badges) and I also have a copy of system 1.0 on my hard drive. I could probably figure out a way to make boot disks but I thought I would ask what would be the best way (more than just find an old mac and do it) to get the system on a bootable 400. I'll have to find access to a mac with a floppy but I could probably find that somewhere.
Any ideas? Links to instructions?
Clipboard File __________ Mar 31, 1985 ________ 4 KB
Finder ________________ May 2, 1984 _________ 48 KB
Imagewriter ___________ Jul 12, 1984 _________ 20 KB
Note Pad File __________ Aug 6, 1997 __________ 4 KB
Scrapbook File _________ Apr 20, 1984 _________ 12 KB
System _______________ Aug 10, 1997 _________ 100 KB
Teach Text ___________ Apr 30, 1988 _________ 20 KB
I'm guessing there are cleaner systems that all have the 1984 date.
If anyone knows where to get those, I'd rather have that
So it's just the individual files.
You need a Mac with an 800k drive, select single sided when you format the disks.
I have no idea how you "bless" the system file. The floppies don't have real folders on them, they are simulated through the finder.
Those dates indicated System 1.1g (the May 1984)
Indeed, there is a "cleaner" .img file out there which has all of the original dates.
I'm a little confused as to the advice being given here ...
First, what kind is your hard drive and what is it attached to presently?
To use the 1.0 disk image, you need a Mac that supports all of the following: System 6, MFS and SCSI, (meaning most Macs released between 1986 and 1990). It's possible to use System 7 & 8 to copy the disk on a SuperDrive equipped Mac, but it requires special care, procedures and software to make a reliable disk. You'll need an 800K disk, you cannot use 1.44MB HD floppies. So a bit more information would be helpful since you ask for options of "more than just find an old mac and do it".
The best thing to do, to get yourself up and running as quickly and painlessly as possible is to check out this link.
When you say "I could probably figure out a way to make boot disks", honestly, there really is no other way to make a boot disk for a 128K without the correct hardware which can only be found on an "old Mac". Once you get a boot disk, you'll still need to come up with a way to transfer files between your more modern Macs and the 128K, which still requires an intermediary Mac to set up. Once you are up and running, you can try a MacTerminal transfer directly to your OS X Mac,via this method, which also works with intermediary Macs up to OS 9 as well.
Even if you eventually use the MacTerminal method, I always recommend keeping at a minimum, a Mac Plus for emergencies and for Making disks for a 128K or Stock 512K/e. The most straightforward approach, requiring the least effort is to obtain some cheap ZIP SCSI & USB drives to move files from an OS X Mac to the Mac Plus. You can also use Mini vMac under OS X to manage disk images and transfer individual files directly without using disk image software.
Also to add, it is a good idea to "bless" the System Folder, once the disk image is copied to a floppy disk. It's real simple to do; just open and close the System Folder itself in the Finder on the machine you are creating the boot disks.
73s de Phreakout. b-)
