Suitable 68k IRC Client?
coius
68030
I am looking for a suitable IRC Client for my PowerBook 520. It needs to be 68k and can support more than one connection (3 at most)
I have tried Ircle, and it's useless. ShadowIRC Crashes the machine at launch. I was going to try Snak68k but I can't find it ANYWHERE on the net and it's bugging me for the lack of IRC Clients for the mac. You would think, with tech-savvy people on the net back then, SOMEONE would come up with a decent 68k IRC Client...
Anyone got suggestions or can send me Snak68k (Demo/shareware version) so I can get on IRC With this laptop?
I can't figure it out. I can't connect to any of the clients other than that ones that are pre-set and there is no way for me to see what I am typing. It's downright useless unless you can connect to other servers, and then on top of that, not being able to see what you are typing is REALLY annoying.
I figured it out easily enough back when I used it. There is a seperate text window for entering text when you are connected. You must be doing something wrong, the app was not that hard to figure out (and I am used to Mirc on a PC).
I second ircle. It's really the only choice for irc on the 68k Mac, in my opinion. Of course, I'm hardly the guy you wanna be talking to about irc.
