so what happened here is , my macintosh se wold only display garbage on the screen , the reset will not do anythng . i belive it is a reset issue . anyone know / have the reset diagrams for a 2x 800k fdd w/ 20mb hdd ?
Issue found . The Sony sound ic (that also holds the reset functions) is dead . I scoped out the cpu, it was stuck in reset . Using the scematics, we found the Sony ic holds reset functions . Anyone know a replacement or compatable ic ?
