Hi guys,
im just coming to end of phase 1 of my SE/30 (called zippy) revival and upgrade project, my next challenge is to get little zippy up and running thoughts a TCP/IP network with my performa 6200 and early intel mac mini which may all be a challenge in itself although i do have an installed network card. anyway my question is about Email, my primary goal is to use zippy as an email client which i know from reading is tricky due to lack of SSL and authentification in old Email software although read Baton has the authentification bit. So specs wise zippy is now 32 bit clean (rom-inator II),128mb, 1gb hhd and a fresh Mac os 7.5.5 install by installing 7.5.3 first then upgrading to 7.5.5.
Now what i wanted to know is there a way around the SSL issue? I.e. running SSL and authentification through my mac mini but how does that work? As I’m not lacking space on my hhd which email software would you recommend? Now zippy is 32 bit clean is it worth pushing it to 7.6.1 or even 8 ?
thanks alot for your help and advise its much appreciated.
Neal
Neal
