Sony Ericsson GC79 wireless card and Wallstreet
bibilit
68030
I collected a couple of weeks ago the following card.
This card is using the Broadcom BCM4306 chipset, so the same as the original Airport one.
I inserted the card in my Wallstreet (Mac OS 10.3) and the card is properly detected as a Broadcom BCM4306 card...I turned Airport on and it started working and detecting the available hotspots, including my own.
The problem is each time i try to enter the password, Airport says this is not recognised.
Moreover, internet is not working, even with a free hotspot and setting the network to manual (DHCP is not working apparently)
The signal's strenght seems to be good.
Any clues?
WPA, probably that is the point because i don't think the card will handle the WPA 256 bits password.
Doesn't work either with a free hotspot and this time i don't understand.
