Software for G4 ZIF processor replacement for Power Mac G3
bobo68
Hi,
I bought a beige Power Mac G3 mini tower. It has a G4 400 Mhz processor installed instead of the original G3.
The replacement is from a company called Metabox (went out of business long ago). I read it is basically the same as Sonnet's Encore/ZIF G4 or Daystar's XLR8 MACh Speed G4 ZIF upgrades and that one can use the respective software to control the accelerator.
Here is a list of these upgrades: http://www.everymac.com/upgrade_cards/by_system/powermac_g3.html
I have been looking for control software (like Daystar's XLR8 MACh Speed Control) but had no luck so far.
Any hints are appreciated.
Best, bobo68
Try Powerlogix' CPU Director - easily obtained, it tends to work with most third-party G3 Accelerators (better than Mach Speed Control, I've found)
I tried CPU Director 2.3b4 and b6 but it would not run on my beige G3 mini tower. It seems to be for OS 9 and OS X (has respective folders with resources and the readme says so) and I installed the system init it produces an error message relating to OS X (ioctl...) on OS 9.
I tried CPU Director 1.5f5 and that works! :beige:  I can now control the 2nd level cache amongst other things.
BTW, the ZIF processor card is a Metabox joeCARD Z 400 Mhz. I think it was a unauthorized clone of a US product by a German company and that was also the reason why they had to cease production.
I rescued some info about the card from the web with the help of the Wayback machine. If somebody is interested drop me a note.
