I'm trying to refurbish an SE/30 to make it useable again but I'm trying to pull some files off it and I've run into a problem.
The machine booted first, second and third try. I got to the desktop and while a little sluggish because I didn't have enough ram installed the disk worked. I ran one of the applications just to verify it was what I needed and the machine hung which I wasn't entirely surprised about because a few of them were very, very early assembly written applications which don't like running on the later macs. On reboot it starts to boot and starts thrashing the drive at the happy mac but nothing happens. I put the mac in slave mode (press the programmers switch to prevent the machine form booting) and plugged it into my powerbook using the SCSI port. Drive setup sees the disk but the machine hangs when you try to mount it after thrashing about for a bit. Disk First Aid can't do anything because the disk is not mounted. Norton Disk Doctor is just as unhelpful. Snooper can't do read/write tests also because it isn't mounted but seek, random sector and SCSI chain tests pass. I'm running out of ideas on how to save the data on this disk.
