Hi folks,
I just received my SCSI2SD 4.2 (the pocket version). But I'm having some trouble getting it started. I've downloaded and run the utility, with an SD card installed. And specified a 2GB disk on SCSI ID 0. But it doesn't appear to be writing anything. The software tells me that it's writing to the device. But when I quit the program, and unplug/replug the device into my MacBook, it doesn't show any volumes mounted. Removing the SD card and mounting it normally through a car reader shows the entire 64gb journaled volume that the SD card had before I wrote the settings to the device. Any tips?
Thanks!
Thanks!
