Setting up a multiple boot system (6,7 & 8) on a SE/30 with a clean ROM
Matias
I am working on revamping a SE/30. Installed a clean ROM (from GGLabs) upped the RAM to 128MB, installed a super silent fan ( [SIZE=12pt]Noctua NF-A6x25) and now I am working on the SCSI2D. I got it up and working great with System 7.5.5. But I must have brain fog because I can’t remember how to partition the SD card![/SIZE]
[SIZE=12pt]i want to configure the system so I can boot up with any of the 3 systems. So I will need 4 or 5 partitions. Thanks for the help![/SIZE]
You can always do the bless/unbless trick to have multiple System folders on one partition. I have an external recovery drive set up that way so I can pre-select a certain System version to boot before I hook it up to the computer in question.
I think I will go with a partition for each System and use System Picker to switch - to create the partitions did you use Lido?
