SE SuperDrives
EvieSigma
Young ThinkPad Apprentice
68020
I'm planning on upgrading my SE to twin SuperDrives. However, I'm not exactly sure what drive specifically was used in the SE (and presumably SE/30) and eBay has loads of SuperDrives with no explanation of what model they came from.
Are the Sony ones the correct model? I'm fairly sure the Mitsubishi ones are not.
I know there's a yellow stripe cable and a red stripe cable, but my SE has red stripe cables...
I may be wrong, but I was under the impression that the SE required ROM upgrade to make use of FDHD drives. I seem to recall that if you put in a Superdrive, it will only work as an 800K drive.
I'll try to test it this evening, as I have one of each(regular and FDHD) as well as an external Superdrive.
You're right on this. You need to upgrade both the IWM to a SWIM and the ROMs to a set from a factory FDHD (or hack up an EPROM adapter and write a new set).
