Hi everyone,
I've been troubleshooting a somewhat bedeviling problem with one SE motherboard that I have. When a floppy drive is connected to the Lower Drive slot, it is unable to properly function. By this I mean you can start up the machine, and stick in a floppy. Sometimes I will get a happy mac, then it will read for a second or two then start doing the "searching" motion with the drive head, and then a System Bomb message will appear on the screen. Other times, if you insert the disk, the drive doesn't even attempt to read the disk and ejects it after two seconds of sitting there. Either way, it does nothing but give errors or not work.
The Upper Drive slot and external connector work perfectly without issue. It is not the drive, because I have tried multiple drives in the Lower Drive slot, and they all do the same thing. Now, I figure it is not the IWM chip simply because the other ports work fine. I looked on the back, and thought that under the microscope that there might be some dry/cracked solder joints, so I re-soldered them all, as well as the filter chip near it. No success.
Is there anything that someone can suggest that might point me in the right direction? Is there one filter that goes to that port specifically that might need to be replaced? I am pretty lost here.
