So in the main today I recevied my first SE. The case needs a lot help, but the main reason I bought it was what showed up upon boot. "Radius Accerator 25". I got it, cracked it open to check everything out. Board is good and clean, and everything seems to work, but the FDD can be a little problematic at times.
Basicly, I want to reinstall System 7 on the hard drive, but I've run into 3 problems. 1. HDD is an aftermarket one, so I need a patched version of HD SC Setup. I remeber reading how to make it, but I can't find the article. 2. I do have System 7.0 on 800k disks, but I need to make sure I have them all. Can someone with antoher set confirm I have all the disks? I'll list them below. Plus, my 800k Disk Tools disk is corrupt. 3. The accelerator drivers. Its seems the machine will boot fine without them, but to take full advantage, I just need to run the image from the Mac Driver Musuem. Is this true?
Thanks everyone. I hope to make this machine into a very productive SE.
Disks:
Before you Install
Disk Tools (corrupted)
Install 1, 2, 3
Fonts
Printing
Tidbits
More Tidbits
Disks:
Before you Install
Install 1, 2, 3
Fonts
Printing
Tidbits
More Tidbits
