I have an SE/30 that I recapped a couple weeks ago. Its worked fine and i've probably put 20-30 hours on it since recapping playing tetris and exploring HD images via my BlueSCSI v2. Its never once crashed or behaved strangely.
Earlier today I was looking at some old documents in ClarisWorks and properly shut down the system. Then later I went to turn it on and no video! I do hear the normal chime on startup.
Some things I have tried:
I did find this similar post mentioning chips UF8 and UG8 https://68kmla.org/bb/index.php?threads/se-30-chime-but-black-screen.4955/
Those chips (all the SOIC package ones) are a little crusty on my logic board due to leaking electrolyte from the old caps but nothing I would consider extreme. Weeks ago I tried to clean as much crust off with isopropyl alcohol and DeoxIT.
- I have a CayMac Vintage "SE/30 Compact Analog & PSU Replacement Board". I've been exclusively using this for a few weeks now with the logic board on the bench. I'm using a Dell display, HDMI to DVI cable and a PicoPSU power supply and its been working fine. So its not the power supply or analog board as those aren't in use with this board. I do see the RGB2HDMI on screen display - it reports its getting no sync from the SE/30.
- Same issue when I tried it with the stock CRT/analog board/power supply.
- I was curious to see if I could access TechStep debug mode over serial. I don't see any output when I try TechStep serial commands using serial port closest to the headphone jack.
- My serial setup is a 2018 Mac Mini and a usb to db9 adapter, with a home made DB9 to mini-din serial cable. I built this cable for using ADTPro with my Apple IIGS. To confirm my cable and setup worked, I connected it to IIGS and successfully made a disk using ADTPro. Is this a valid test for using the same cable with TechStep on the SE/30?
- Pinout for my cable is shown here: https://adtpro.com/connectionsserial.html halfway down the page. Its wired as a NULL MODEM
- I tried re-seating OEM ROM SIMM and putting some deoxit on the socket and the SIMM just grasping at straws at this point.
- Removed socketed chips and put DeoxIT in the sockets, re-installed chips.
- I have a Floppy Emu connected - I don't see the mac attempting to boot from it.
