SE/30 weird floppy drive issue
ronan
Hi everyone,
I'm becoming crazy as I have huge trouble making my original floppy drive work reliably. I have been investigating this for more than one week nearly full time.
It looks like my drive is working sometimes but not always :
Sometimes it will just eject the drive quickly. Sometimes I will be able to format a disk, write to it and read from it with no issues. I am also able to write disk images using a modern mac and sometimes see the files on the SE/30 itself.
I sometimes manage to boot System 6 floppies, sometimes it half boots and sometimes it never boots. I never managed to boot from System 7 floppies.
The eject mechanism works great, there is not that much dust. I did clean it fully and lubricate it, as well as clean the head with alcohol.
It did work perfectly one year ago.
I'd like not to buy a FloppyEmu for the time being.
I did try with 10 different floppies that were known to work well a year ago.
I did check most traces between the CPU and the floppy port on the Logic Board. I attached the traces I tested.
Do you have any ideas why this drive would behave in a random manner ?
Thanks a lot for your help.
PS : did I say I'm becoming crazy !?
I had a similar problem see link below.  Check your Dxxx and Axxx data traces between IC's.  I see you ahem recapped the board,  mine was caused by a broke trace near C9.
I see.
Do you have any hints on how to figure out which between the logic board and the floppy drive is having an issue first ? (whithout buying a new drive)
I'd like to avoid testing 1000 traces for nothing :p
I would start with the chips that have traces passing by any caps so UK11, UK12, UJ11, JI12, UG12, UE11.  these should all have D and A connections and pass but eh group of caps  around C9.  I started with identifying any visual damage, and then looked at the traces around that and started there.  Also built a spread showing pin on origin chip and pin on destination pin for easy lookup while holding the multimeter probes.
