se/30 sanity check before I create an issue on github
Hi folks,
I was buzzing out some traces on my se/30 and used the (amazing) redrawn schematics to assist.
I think I found an error, which needs to be cleaned up but before I open a github issue against the project I wanted to ask for a sanity check first.
Problem: the 68030 has 13x13 pin array, so the row letters should be A-M and not A-N as they presently are.
This will trickle down into the various places where the rows are referenced by index, such as the data buses, the pin matrix (sheet 10), etc.
Have I got this right, or is my eyesight failing me?
Thanks!
A to N is correct. „I“ is always left out on a pin matrix probably because it could be mistaken for „1“
