Can anyone tell me if the screen on an SE or SE/30 will do anything with a bad logic board? I am trying to restore an SE/30 that had a bad PSU and possibly more, when i got it it was dead. I recapped the logic board and analog board and got a new known working PSU from an SE dual drive. Hard drive spins up Monitor does nothing just black, Even when adjusting the brightness wheel. To troubleshoot i put the working PSU back on the SE Analog board. I know the SE gets screen and boots although with vertical lines. Is the SE/30 screen dead? Thinking back i should have just put the se/30 logic board in the SE to test it... How does an SE Monitor act with a dead logic board, is it just black with zero activity or does the screen glow at all?
Edit, i do not get a chime on the SE/30.
Thank you sorry for the lengthy explanation!
