Since I need to wait on RAM chips for the 128K, I figured I would work on one of my extra nasty SE/30 boards. LOTS of corrosion from the leaky caps. No problem popping them off with the hot air station, pads cleaned up fine. 30 minute of vinegar and a toothbrush got most of the fuzzy off, but the video area is still pretty nasty and UE8 popped off. I'll try another soak and scrub in that area, but at this point might to worth just proactively replacing all those chips?
Any tips for retinning the pads? Feels like I'll need to hit them with light grit sandpaper of something, to much corrosion for even fresh flux to deal with. Also, any gotchas when ordering new logic chips? Schematic says 74LS166. Looks like this should do the job.
https://www.mouser.com/productdetail/texas-instruments/sn74ls166ad?qs=sGAEpiMZZMtsbn1GaJysl8drSYt3ukOhxRl7aLOSxWU%3D
