So, I completed my first SE/30 recap last weekend. Bad news, was the machine would not boot afterwards. No chime, no screen, thought the fan would start, and if plugged in, the HD would spin up.
Noticed a couple of things. First was that UE8 still had some gunk near it. Gave it a good second scrubbing, but that didn't help.
I had had a problem getting the negative leg of C2 (the big axial cap) loose from the MB, and the backside of the MB got a bit chewed up. Cleaned up as best I could, but it looked like I might have scraped up enough to expose some other traces. Trying to resolder this joint didn't help.
With my imperfect schematic reading skills, I saw that C2 and C5 negative were both supposed to run to ground. So - I freed the negative leg of C2 and jumped with a wire to the negative of C5 (a tant which is right next door to the neg leg of C5).
With that, the machine came to life - bong, nice steady screen, etc.
However, while the sound is good and loud, there is a steady ticking coming from the speaker (about 2-3 per second), and a little bit of grumbly static underneath everything. The static seems to get slightly softer/louder as I adjust the volume, but the ticking is same no matter what the volume is set at.
So - is it plausible that my sharing ground between these two might be causing these issues? I see that C2 and C5 are both involved with UB10 and UB11, which are the sound chips.
Is there a better place to bring the ground from C2?
I know that C6 is also referenced a lot with sound problems, but I checked it and it seems to be a solid solder job on the new cap. No other obvious goo around the other UE* chips.
Thanks for any advice!
