1) Pin 8 to the logic board (+12 volts) has capacitors 2 and 25 in parallel and they seem to be intact. It also has 2 resistors (R14 and R15, with the number "100" on them but listed as 10 ohm resistors in the schematic) in parallel. When I measure either R14 or R15 I get a short. Is this really a short since they are in parallel? If I had a working logic board I'd just measure and go from there.
2) Bonus question: Does the SE/30 require the -12 volt line to be intact to boot/give chime?
Thanks to anyone.
Thanks to anyone.
