Hi,
I've been reading this forum with interest for a while before getting round to reviving an SE/30 that I was given last year. I finally had a go at it last week and have made some progress, but it's not happy yet.
Story so far:
The machine came to me unexpectedly with some other equipment. No keyboard or mouse but in good shape.
Inside I find no hard drive, and a clean motherboard with no Pram battery (yay!). The ROM SIMM was propped up with cocktail sticks, though. First power up got a very faint chimes of death and nothing on screen.
Working through with the schematic and a scope, I found a faulty 74393 in the video clock divider which meant there was no horizontal drive to the monitor. Fixing that got me working monitor but blank screen. Then the 74166 video shift register turned out to be faulty. Now I have action on the screen - a sort of rug pattern which looks like uninitialised memory to me. It's not the horizontal simasimac stripes.
I've replaced all the horrible surface mount electrolytics. That brought the chimes of death up to full volume. I gave the PCB a good wash and dry and gave all the SIMMs a cleaning with DeoxIT. Now the cocktail stick is not required.
I later found that two of the 74F258 RAM address multiplexers had stuck outputs, so I've replaced those. The outputs are no longer stuck but there's no change in the symptoms.
I could spend hours looking for broken traces and vias, but I prefer to go at these things systematically. Can anyone tell me what the tests performed before the chimes of death actually are? I'd like to figure out where it's failing. I'm fully equipped with logic analyser, scope and a whole vintage computing workshop.
The machine currently has no keyboard or mouse or floppy or hard drive connected. It should still start up and ask for a disc in that state, shouldn't it?
Thank you
Chris
Warsaw, Poland
Story so far:
Thank you
Chris
Warsaw, Poland
