Hello all,
I recently recapped an SE/30 motherboard. I cleaned the board with a toothbrush and soap and hot water, let it dry for a week or more and then replaced the capacitors. All the chips and traces look good on visual inspection. It boots and works fine, but the internal SCSI bus will not see a drive. I can connect an external SCSI drive and it can boot from the external but still not see the internal drive. I've tried a few different drives. Also, I suspected it may be power related so I replaced all the capacitors in the Sony power supply and recapped the analog board as well, no change. Any idea what would cause this? I have a Doug3 rom SIMM on the way to install so if I cannot figure this out its not a loss.
Thanks
Thanks
