SE/30 Endless boot when AppleShare and Shared Library Manager extensions are active
My SE/30 is giving my trouble during boot sequence:
There is a 1'30" delay between the moment the toolbar appears and the moment the content of the desktop (HDD, Trash...) mounts.
Appart of this, the machine (Recapped, new battery, 128Mb RAM, SCSI2SD, Ethernet RJ45 card, Daystar Powercache 33Mhz card, ROMinator 2, OS 7.5.5) works (quasi) like a charm.
The only way to get rid of those annoying 1'30" is to disable "AppleShare" extension and "Shared Library Manager" extension.
I have trashed the ASLM pref, disabled AppleTalk, checked the HDD with DiskDoctor 2 and 3, zapped the PRAM, rebuilt the desktop...
Does somebody have ever experienced a similar issue?
Yeah, I've seen that delay on a blue & white G3 running OS 9. Super annoying. I never found any work-around or fix other than to disable some Extensions.
