SE/30 Capacitor Trouble
Tempest
It appears that the caps in my Mac SE/30 have finally died. There were signs of trouble for awhile now such as no sound through the internal speaker, but when I went to turn it on today I was greeted with a screen that showed garbage every so many columns on the screen. The Mac itself is running fine (System 6.0.8 loaded right up), but obviously it needs help.
Is there anyone out there that can do a capacitor replacement for me? Name your price or I can trade some items for your time. The SE/30 is in amazing shape, I'd hate to see it rendered useless.
I'm in southfield, You could bring it over one day, I can show ya how to re-cap it.
also aftermac is in romulus, we've wanted to have a cap party for months now... just so busy with the babies.
yours will be one sunday about 8 hours, for yours I want to get the aluminum can kind... so they look stock!
Wow, I'm in no rush, stock is cool just looking to make the fleet working. By the way you are awesome. I kept a Mac II board since there was so much room to work on the board figured I would try my luck. It turns on, no video from card, no chime, and will not turn off so well see after I get a newer iron and caps if I can get it done. All that open space is much less intimidating. That classic board is so small my old iron is as big as the capacitor lol.
I totally forgot about Jason (Aftermac). I figured he was too busy with the kids and all. We should have a Mac party sometime in here. :)
I think I'll send it to Phreakout for him to have a look at since he has the time to do it now. I don't want to wait since if a cap has blown it's probably leaking all kinds of wonderful stuff over my motherboard.
Hey, is it too late to join the SE Michigan Logic Board Restoration League? ;D
I'm in Royal Oak - and discovering an alarming number of leaky capacitors in my Macs. :( And with nearly zero soldering experience, I could use some help...
That's not a good idea. They will eventually leak again, giving even more problems in the future. By future I mean many years of course, but these are getting rarer and rarer thinking how easily the mobos break because of leakage...
Use tantalum capacitors, please.. :( They can leak too I think, but I've never seen any leaking tantalums. Not to mention that they last extremely long.
Well my SE/30 is going off to Phreakout, but my beige G3 tower could use some work. It's ok, but the fan makes a horrible screeching sound sometimes and I'm sure it could use some other maintenance so I'm down for a Mac party sometime in here.
I'm thinking of going with aluminum organic polymers in the future. They're twice the price but have the stock look and my understanding is that they won't leak like an electrolytic will.
The ones i am putting on will last as long as the old ones, maybe longer,cap technology is better now adays!
I am going for "stock look " for macdrone, they never came with tantalum caps,
If i was recapping a Q700 board that originally came with those caps then that is what i would use.
Mcdermd has the right idea, it has to look the way it was from factory originally, That is my goal.
Just like some people here say not to twist the caps off, I twist every one off, every time. it works great,
also i leave the snapped off old leads on the pad, no reason to remove them.
- Snap off
- Remove all debris
- Clean leaky goop with a damp paper towel
- buff off corrosion if there is any, or skip this step
- flux
- Swiftly heat up , apply fresh solder
- reflux
- set cap, and heat up each side, if you do it quick enough with the alum can kind it will sit nice and flat just like stock.
if you are not quick it will be crooked, but don't be anal, minimize how much heat you are putting into the pads!
if the cap is sitting cocked, but you can see the solder has flowed and properly, and connected the lead to the pad, just leave it.
- I try to massively limit putting heat on the pad !
The more heat you put into the pad, the more likely it will lift.
Vary rarely do i lift a pad. But some days are bad days,
Also don't be a worry ward, just get in there an replace the caps.
some of you will fail, and even if you do there are pros out there like technight and phreakout that have blue prints
and they can use wirewrap and follow traces, if needed!
I received a IIci from captainbob , He gave it to me for free, lots of pads were ripped clean off. Someone had F^%$#^ this thing all up!
i did some very ugly re-work to make the connections still happen, I had to be vary patient! Was able to make all the connections, it works great now.
Yeah, they do not have a fluid inside of them. They seem to get a good recommendation as a high reliability tantalum alternative from NASA:
A destructive test with massive current over stress to fail the polymer aluminum capacitors reveals that all polymer aluminum capacitors failed in a benign mode without ignition, combustion, or any other catastrophic failures.
Source: http://nepp.nasa.gov/files/20389/09_005_GSFC_Williams_Liu%20APC%20Final%20Report.pdf
Tantalum, ceramic, and polymer capacitors are all dry types and any one of these will be vastly superior to the electrolytics.
I'm not actually sure why surface mount electrolytics are so bad. Through-hole types tend to be a little larger but even the smallest types have better specs than the SMT ones.
Until now I hadn't really given much thought to Conductive Polymer Caps in my SE/30 logic board recappings mainly because SMD tantalums look great and will last for decades (assuming reasonable temperature, humidity, and no voltage spikes). But this thread does make a good point about Aluminum Conductive Polymer Caps offering a "stock" look, especially for those among us who keep their SE/30's open enough to care about such things or who intend to sell boards and expect a higher selling price as the result of a "stock look." Here's a set of excellent information that can help you decide if Aluminum Conductive Polymer Caps fit the bill for you:
General Overview of Polymer Capacitors:
http://en.wikipedia.org/wiki/Polymer_capacitor
An excellent set of info on polymer caps, especially when replacing "wet" electrolytics with them:
http://www.capacitorlab.com/capacitor-types-polymer/
Life Expectancy vs. Temp. & Humidity (see pg. 5):
http://www.cde.com/catalogs/SPAAppGuide.pdf
Various capacitor technologies compared:
http://www.bundertech.net/cap.php
Nichicon Conductive Polymer "Long Life Assurance" Aluminum SMD caps:
http://www.nichicon.co.jp/english/products/pdfs/e-p_cs.pdf
