I created a 2GB SCSI device on the SCSI2SD v5.1. Formatted (using Lido in 7.5.3 boot floppy on a Mac II) and Mac II only recognizes about ~175 MB.
I want to start over -- i.e. I want to 'delete' this SCSI device and add it again with a size of say 200MB only.
How do I do this? I see no options in "scsi2sd-util" utility to remove a SCSI device and re-add it.
is the answer that I need to wipe the SD card, or destroy the created volume on the SD card first? Then resize the SCSI device down to the alternative size, then reformat using Lido?
Thank you!!
Thank you!!
