Every time I run the SCSI2SD utility, write the appropriate settings for a 68k mac (or any settings for that matter), and re-open the utility to double check, my settings are reverted to default.
I've tried this on both Win7x64 and OS X 10.7 with the utility from CodeSRC. It recognizes the device, it writes the settings, and then after re-opening, I've got bupkis.. all the device configs are reset to defaults. (in reality I'm only writing one device)
Any thoughts or things to try to keep this from happening?
Thanks
Thanks
