Got my SCSI2SD v5.1 with a Kensington 16GB SD card and plugged it in to my SE's internal SCSI via ribbon cable. Didnt touch the factory settings or update firmwear. Initialized the card with the patched HD SC setup 7.3.5. Viola! There it was mounted on the desktop. Opened it up and had 127 kb used and a bit over 4 gb available. But when I tried to copy a readme doc onto it it said that 36 mb additional space was needed! Tried reinitializing it using partitions, full Macintosh, half Macintosh, etc no luck. Tried Lido which was much worse; no mounting and caused a system bomb.
Is there a small partition on top causing the lack of space? I think I saw one and tried to move it down with no luck.
Any thoughts?
Any thoughts?
