I have a big old external SCSI enclosure with 16-bit 68-pin connectors on it. From what I read the SCSI standard is supposed to interoperate and if the physical connection can be made that should operate as an 8-bit SCSI peripheral also. So if I was to find a Mac 25-pin M to 68-pin SCSI M cable I should be able to connect it? Another possibility might be a regular Apple SCSI cable with an adapter converting Centronics 50 F to 68-pin M?
Then once the physical connection made what does a System 7.5 Mac need to see device connected in this way - I expect hard drives just show up with Lido or similar. How about a CD-ROM drive, they should show up as read-only once a readable CD is inserted? How were other devices such as scanners managed?
(I would buy an external SCSI housing with Mac-style Centronics 50F connectors but they are not common)
