SCSI and powerbook goodness!!!
coius
68030
yes, few things came in the mail today, as well as on the body of a friend :p
Scores today:
PowerBook Lombard LCD and top
I had to take this apart and piece it in bit-by-bit due to one of the screws on the hinges of the original not wanting to come out. This was to cure my powerbook of 2 lines running down the screen of stuck pixels
PowerBook SCSI Block
Includes a switch to do SCSI mode! (FYI, when the powerbook was set to boot from OS X, it wouldn't enter, but if it was set to OS 9, then it would)
SCSI Cases and burners:
Yamaha 8x4x24 SCSI Burner and case. Came with SCSI-2 Cables (mini 50-pin or 68. not sure since the burner itself is 68-pin) Has built-in terminator that can turn on and off.
Ricoh Burner (unkown speed, will find later) SCSI CD-RW w/ case. came with Cables and terminator.
other cables, include a HDI-30 (or whatever apple uses on their powerbooks) -> SCSI-2 (or mini-scsi, for the yamaha), a SCSI->Centronics (25->50-pin)
SCSI-2 (mini-scsi)->Centronics.
few other things:
Extra SCSI Terminators, SCSI HDD (1GB) from a 7200. Jaz Cartridges (3x1GB, 2x2GB). I got a drive for it :)
Zip Discs (100MB/75MB/25MB) which I have no use for since I don't have a Zip Drive externally (anyone remember the "Economy" disks? did below 100MB)
Anyways, that was my haul for today!
