Screen longevity
bbraun
Having several modern CCFL backlit LCDs that have gone dim, I'm wondering how well the 68k portables' LCDs hold up to age. What are some of the common problems, and what should one look for when shopping for a 68k portable these days?
The only issue I have run into is on an old Powerbook 170. It suffered from black corners of the LCD when on for a long period of time.
All my other powerbooks work fine. Mind you the dual scan screen on the duo 230 is terrible.
I had the tunnel vision/darkening corners fault on a Duo 280 greyscale. i think that's a fault in the LCD itself rather than the backlight, but I am open to better information.
In my experience, passive matrix screens can have leaked caps, causing screen issues such as a faint display/occasional "yellow-out" issues. I had it happen to a PowerBook 140 and a PowerBook 160.
Where are the guilty, leaking caps?
It's an interesting suggestion. My PB160 has a fairly poor greyscale display (which improves dramatically when set to display Black & White only), and I had a 145b that I had to junk because the display was so bad. The logic boards look pristine.
It would be relatively easy to take the lcd apart and have a peek - even washing might do the trick, or else minimally help with diagnostics.
Mind you, I recently got a PB180 on here with no display problems at all, and that seems to have cured my PB1xx series wanderlusts for the present. The PB160 and its screen will have to wait.
With enough patience, precision, and critical thinking, you can replace the lamp(s) in most LCDs. I have replaced lamps in two PowerBook G3 Pismo screens. One was dim, the other had turned pink in the corner, and it was spreading.
I'd imagine very very old LCDs couldn't be any harder. I sourced my lamps at Digikey with some help found googling. They have a huge selection. If you screen is dim or tunneling, remember this as a possible option if you trust your fine motor skills.
I have a PowerBook 1400cs and a Powerbook G3 Lombard, but I bought it from a site with the same idea as eBay, so I don't know if it is intended to be brighter.
It is stupidly easy in the displays in the 1xx series.Like, mars478 could do it.. though he might break the lamp later.. but meh. :p hehe
I have two 150's here that have entire sections of the screens dead. They partially work, but those dead areas make it impossible to really use them.
I have a ton of old Thinkpads with great screens from the mid 1990's, yet a few newer with some pink or dead bulbs. If I had to guess I think the older smaller screens had bulbs that just last longer then the higher output bigger screens.
I have a 190 like that. On mine, there is a bad connection between the printed ribbon cable and the actual LCD. I found this by touching and wiggling various parts. A possible solution is to wedge something in there that keeps pressure on the affected area.
